Latest Microsoft Update - Outlook 2013 Folder Pane blank
- Latest Microsoft Update - Outlook 2013 Folder Pane...
11-09-2013 9:35 AM
If you have an issue like me with the latest update, do a Google search & you'll find the above solution. Hope this helps.
Re: Latest Microsoft Update - Outlook 2013 Folder Pane blank
12-09-2013 1:34 PM
http://www.infoworld.com/t/microsoft-windows/microsoft-botches-still-more-patches-in-latest-automati...
12-09-2013 1:41 PM
The Word and Outlook 2003 worked ones OK but the Excel 2003 one didn't Security Update for Excel 2003 (KB2810048) so have removed that one and hidden the remaining three
The Excel one is also mentioned in the comments of that link
12-09-2013 1:56 PM
12-09-2013 3:02 PM
You can hide the office 2007 updates and they will no longer be offered to you.
In Widows update right click on the relevant update and select "Hide Update"
12-09-2013 10:48 PM
13-09-2013 11:55 AM
13-09-2013 11:57 AM
As a matter of interest which type of files have a .dos extension
13-09-2013 12:09 PM
I now use Libre Office.
13-09-2013 12:25 PM
13-09-2013 12:54 PM
LibreOffice easily opens .dos (& .docx) text files directly as I said in my post, but I could do without M$O butting in! I guess that Strat is in the same boat.
13-09-2013 1:00 PM
13-09-2013 1:03 PM
13-09-2013 4:56 PM
.dos was a typo!
wrist slapped!!
14-09-2013 12:59 PM
