Laser printer recommendations
- Laser printer recommendations
22-06-2014 1:13 PM
So I am thinking of getting a, reasonably priced, mono laser particularly for my OU stuff. Searching through past posts here hasn't really given many clues although Dom S mentioned the Brother HL-5380DN but that is way beyond my price range.
Speed isn't a concern but I'd prefer wireless as well as duplex as standard. The Brother HL-2250DN looks ok but wondered if anyone else has any comments/recommendations for me, please.
Forum Moderator and Customer
Re: Laser printer recommendations
22-06-2014 1:53 PM
For example, I've just bought one of these for £100 all in from a different trader. It's quite big and not very quiet but it's fast and well built.
Edit - link fixed
22-06-2014 2:01 PM
Some prints require quite a large data transfer to take place.
Note that a wireless connection requires a transmit to the router, followed by a second transmission from router to printer.
A USB connection only requires a single data transmit.
BTW I use a cheap rebadged Samsung (a Dell) for my OU stuff.
It didn't come with proper Linux drivers, despite claims to the contrary.
I made it work though!!!
22-06-2014 3:00 PM
22-06-2014 3:28 PM
Quote from: pwatson Does it have be small and does it have to be new? Take a look at ex-office printers on ebay... A good workgroup printer can be had for around £100, will be much cheaper to run and probably much more reliable.
Typo in the link!
York.
22-06-2014 3:47 PM
Quote from: Hairy +1 on a 2nd hand laser.
It's a very long time since I bought a laser printer, I just pick them up on a Freecycle.
Usually a quick clean of the insides and rollers and a new toner cartridge (often given away too!) and they're up and working.
My current collection is a LaserJet 6P (bombproof and my main everyday printer on W7x64, shared across my network), Brother HL-1250, Samsung ML-1510 and HP Laserjet1300.
22-06-2014 8:32 PM
I'll do some research based on the suggestions.
I may decide not to buy as it really depends on what I can get within my budget which may stretch to £100 but may not if SWMBO gets her way
22-06-2014 9:39 PM
I bought a used Brother HL-5130 on Ebay for £1.98 (collected locally) it was like brand new but the toner cartridge was missing
Bought a toner cartridge from Smart Cartridge for £25. all been perfect. Got to be the way to do it.
24-06-2014 10:44 PM
Not sure about eBay at the moment as I'm not up to sorting out any major hardware problems if any arise in getting it to 'go'. A few years ago perhaps but just not now.
I have seen the term LED printer banded about. Is that just another name for laser or is it a completely different beast?
I have been looking at this Epson. Any comments, pleas?
24-06-2014 10:58 PM
Not many reviews
Toner v.expensive and only lasts for 2500 pages
24-06-2014 11:11 PM
They have been around for a while, just slightly different technology for creating the image on the photosensitive drum, but basically very similar.
Quote from: Mav I have seen the term LED printer banded about. Is that just another name for laser or is it a completely different beast?
I think Samsung might have produced them first and they were a bit cheaper.
03-07-2014 3:17 PM
I'm seriously considering the Brother 2250 which has got some good reviews. It has automatic duplex but Ethernet rather than wireless but that isn't a problem as I do have a spare power plug available.
After a bad experience using compatible inks with an inkjet several years ago I have always stuck with the manufacturer's ever since no matter what make/model. But what about compatible toners? Are they more reliable?
03-07-2014 3:19 PM
depends on the usage
03-07-2014 3:25 PM
Just to contrast with my HP inkjet: all five inks were replaced around a month or so ago. Very little yellow left, around a third of cyan/magenta each and about half the black. The photo black is hardly touched. Very little colour printing involved as most has simply been black text no more than a dozen or so pages on average a week.
Every time the printer is turned on/off it does it's 'thing' which much drain a fair bit of ink before it even starts a print run.
03-07-2014 3:39 PM
