Laptop touchpads
petlew
Laptop touchpads
I loathe touchpads...
My previous defunct laptop touchpad had a button on it to switch it off (wonderful) The replacement laptop doesn't have this button and I constantly when typing inadvertently touch it and do something I don't want.
I realise, that I can disable the pad in Device Manager, but in the event of a crash, I may not have the use of a mouse.
Is there a keyboard disable/enable option?
6 REPLIES 6
pwatson
Re: Laptop touchpads
What laptop? What OS?
More details required!
nadger
If you are using Win10 try Settings/Devices/Mouse & Touchpad/Related settings/Additional Mouse Options.
You can then disable internal pointing devices when usb mouse attached.
HTH
NedLudd
True! I use this on my laptop together with an MS Bluetooth mouse!
The touchpad remains active until I use the BT mouse then it's disabled!
Geoff,
York.
petlew
Thank you guys.
HP Pavilion G series. Win 7. Logitech wireless mouse.
pwatson
petlew
Kiss to pwatson
