Laptop speakers
shermans
Laptop speakers
I have a laptop with internal speakers.  However, when watching DVDs in hotel rooms on it, the volume is sometimes a little low and it would be nice to be able to increase it - the only other solution is using headphones, which is irritating.
So I thought about getting some external speakers for it.  In Poundland for instance, you can get external speakers for - you guessed it - £1 !  But before I go to the bank to negotiate a loan (now that interest rates have been cut, I can afford it it at last), would these actually be any louder than the internal speakers on the laptop ?
I suspect really that to increase the volume, I will need some sort of speakers with their own USB power supply ? But why spend £10, if £1 at Poundland will do all I want, namely just to increase the volume just a bit ?  Will it or won't it ? Roll eyes
Fixes: 135
Re: Laptop speakers
What is the spec of the Poundland speakers. If they are not powered then it's unlikely the improvement will be substantial.
Customer and Forum Moderator.
Re: Laptop speakers
what model laptop, which os?  there may be ways to tweak the volume.
Re: Laptop speakers
You really need a amplified set of speaker as if your out put is say 8 watts thats all you can get without amplification. If its only a slight tweak then cheap external speaker may just do it as the internal ones may be muffed within the laptop depending were they are. So for a pound its worth a try you can put them nearer to you which may just do it as well
Re: Laptop speakers
I think if you buy a set of speakers for a pound, they will sound like a set of one pound speakers.
I got myself these http://www.amazon.com/Sony-SRS-T88-Compact-Portable-Speakers/dp/B0001RMAA0 a couple of years ago.
I got mine at a Sony outlet, they were "refurbished" but as new and only cost 20 dollars. The sound is excellent.
I use them when travelling and they fit inside a shoe in my case!
I don't know if they are still available but I would recommend something similar for your travels.
VileReynard
Seasoned Pro
Fixes: 11
Re: Laptop speakers
I think it is likely that any external speakers will sound louder than the cheapo ones in a laptop.
A larger speaker - especially if in an enclosure will sound louder.
Don't expect hi-fi for your £1 though...
You pays your money and takes your choice  Smiley
shermans
Re: Laptop speakers
OK, you've convinced me, especially as the VAT is only 15% now !  Do you think they will change their name to Ninetyeightpenceland ? Smiley
Seriously, thanks for your various comments - what have I to lose ?  And if it doesn't improve things, then I'll get some Amazon speakers as suggested by Santiago.
Cheers.
