Laptop slow start up after windows 10 update
- Laptop slow start up after windows 10 update
24-12-2017 11:36 AM
Since the latest Windows 10 update my laptop i5 6GB Ram which normally started very quickly after shutdown was slow
I changed the Power options its now quick again
Type power options in search you will get Power & sleep
RHS click on Additional setting
LHS click on Choose what power button does
Check if Turn on fast start up is ticked if not click on Change setting that are not currently unavailable
You can now tick the fast start up box
Don't forget to Save Changes
Hope this helps anyone who has had the same problem and a happy Christmas Brian A
Re: Laptop slow start up after windows 10 update
24-12-2017 11:53 AM
I've always found updates to Windows more likely to turn Fast Start Up to ON rather than OFF
24-12-2017 12:04 PM
Thanks @Anonymous - that probably explains why my mums' machine slow to start - I'll give it a look over next time I boot it.
27-12-2017 9:18 PM
I have a computer that dual-boots between Windows 10 and Windows 7. This is incompatible with fast start-up as Windows 7 sees all connected hard drive partitions as not correctly shut-down. So I turn off fast start-up but every Windows 10 version update so far has turned it back on.
28-12-2017 5:11 PM
It's very misleading.
This "Fast" thing just pretends that Shutdown = Hibernate
