Laptop no power
- Laptop no power
Laptop no power
02-04-2015 2:57 PM
have taken battery pack out and cleaned the contacts , to no avail .
any ideas
Re: Laptop no power
02-04-2015 4:15 PM
I would guess the power ribbon has slipped out a bit on yours?
On the Toshiba when the big power button wasn't working there was a couple of small "help" buttons underneath that continued to work booting to a Toshiba windows help page,
Any extra similar buttons on yours?
Re: Laptop no power
02-04-2015 4:35 PM
and Mr Google is not much help
Re: Laptop no power
02-04-2015 5:30 PM
I had an ASUS that did it, then I did a BIOS reset and all was well & good until the display went kaput.
Re: Laptop no power
02-04-2015 5:38 PM
Re: Laptop no power
02-04-2015 5:45 PM
Hopefully it's something simple that can be sorted with a bit of screwdriver spinning, often the most annoying problems are the easiest repairs...
Re: Laptop no power
02-04-2015 6:31 PM
If still no joy will try to disassemble it tomorrow
Re: Laptop no power
02-04-2015 6:41 PM
Re: Laptop no power
02-04-2015 10:35 PM
Re: Laptop no power
02-04-2015 10:46 PM
Could be something as simple as the power jack on the main board has come loose (quite common) but often slightly more "terminal"
Re: Laptop no power
02-04-2015 10:50 PM
This video may be helpful on disassembly....
https://www.youtube.com/watch?v=aFVZT15fRg4
and this video on about repairing the power socket.... may be helpful.....
https://www.youtube.com/watch?v=fW-q8fVgAbo
Re: Laptop no power
03-04-2015 8:26 AM
Re: Laptop no power
03-04-2015 12:11 PM
so the laptop is DEAD
Re: Laptop no power
03-04-2015 12:37 PM
Even I don't attempt soldering on that small a scale...
Re: Laptop no power
03-04-2015 12:43 PM
Quote from: rongtw after following the video i found ![]()
1 ribbon cable soldering to motherboard has come off
Can you post a photo?
