Laptop mains
- Laptop mains
Laptop mains
21-08-2018 11:57 PM
My laptop PC which has been my main computer for some years, since purchase has never been disconnected from the mains supply, except once to install an SSD about six months ago.
The SSD doesn't generate much or very little heat, unlike the former HDD. The power pack is well ventilated and just gets mildly warm. Its connected via an APC so is largely unaffected by power cuts.
I expect some would consider this bad practice...
But is it, and why?
Re: Laptop mains
22-08-2018 2:51 AM
Moderator's note:
Thread moved from General Chat to Tech Help.
Forum Moderator and Customer
Re: Laptop mains
22-08-2018 7:30 AM
Some people are of the opinion that it isn’t good for the battery as it doesn’t discharge / recharge and can affect the life span of it. But I am curious to know why you need a UPS on a laptop that in effect has its own one built in. i.e. the Battery.
If you’ve not got the battery installed all well and good as you’re powering it like a desktop, but that then kind of makes your OP moot. If the battery is installed then why the UPS?
Re: Laptop mains
22-08-2018 7:37 AM
But agree with mook, a UPS is overkill if you have a battery in that lasts long enough for you to shut the laptop down in even of power failure!
Re: Laptop mains
22-08-2018 9:56 AM
Agree with the responses so far.... Like you, I have my laptop plugged in and charging all the time... it is on from about 0800 to 1100 and then from about 1300 to 2359... ! Occasionally, I remove the power plug, and let it run the battery down... it only has a life of about an hour or maybe ninety minutes anyway.. I never take it away from the desk, to use as a "mobile" laptop... I have a small 10inch one for that,.
I could remove the battery.. but it leaves a big hole in the back !... actually, that may not be such a bad idea as it will help to ventialate the machine... despite the fact that I have fixed a wooden strip across and under the screen hinge area so that the keyboard has a slope to it... Makes it easier to type on.... and also gives room underneath for better ventilation .
Re: Laptop mains
22-08-2018 2:50 PM
@petlew wrote:
... Its connected via an APC so is largely unaffected by power cuts.I expect some would consider this bad practice...
But is it, and why?
Unless your router is connected via another UPC it seems a bit pointless.
Also, are you monitoring the state of the UPC batteries?
Re: Laptop mains
22-08-2018 3:16 PM
I am
Re: Laptop mains
22-08-2018 6:23 PM
The usual advice with rechargeable batteries is to let them go completely flat and recharge them fully a couple of times a year, but I've never found this to make any difference to their lifespan.
My experience with laptops (I'm on my fourth one) is that the battery lasts a shorter and shorter time to the point where, after about four years (less with the two older ones), there is no point running the computer off the battery since it only lasts about 30-40 minutes.
Re: Laptop mains
22-08-2018 8:00 PM - edited 22-08-2018 8:01 PM
It depends on the battery chemistry. That's rather outdated advice now dating back to the likes of NiCd batteries...
Re: Laptop mains
23-08-2018 6:20 AM
Ah! the APC, its use for the laptop is more accidental than technical. It happens the mains plug to adaptor lead has the same adaptor end socket as the redundant desk top computer power input socket. When the time came to change the computers over, I simply unplugged the decktop and plugged the mains power lead into the laptop adaptor socket. And its been that way ever since.
I've never thought much about plugging the router into the APC, they're in the same room but around 4/5 meters apart and not a straight line across doorways connect to the APC, but it wouldn't be a difficult job to move the router though, uhmm! I might consider that.
Likewise, I haven't thought about removing the laptop battery, but I will now.
Thanks for your input guys.
Re: Laptop mains
23-08-2018 9:34 AM
I had a laptop for a few years and the power supply died so I bought a replacement.
A few weeks later the laptop died
Re: Laptop mains
23-08-2018 12:19 PM
@Strat Where should we send flowers? ? ? ? or would you prefer donations to a charity ? ? ?
Re: Laptop mains
23-08-2018 2:05 PM
@shutter wrote:
...would you prefer donations to charity ? ? ?
It's a wicked lie. I have never met the woman.
Re: Laptop mains
23-08-2018 6:37 PM - edited 23-08-2018 6:37 PM
My first laptop has a Cadmium battery which was useless after a few months. The three others have Lithium batteries, but all have come with the 'periodic complete discharge' advice. I'm not sure what kind of battery my toothbrush (bought in 2010) has, but that used to last three weeks, however now it's more like five days, and when it dies, it dies suddenly, i.e. within one brushing session.
Re: Laptop mains
23-08-2018 6:54 PM
Lithium batteries don't suffer with the ''memory' issues of other chemistries, and fully cycling isn't necessary or recommended.
https://batteryuniversity.com/index.php/learn/article/how_to_charge_when_to_charge_table
