Laptop for projector
- Laptop for projector
20-09-2009 8:39 PM
Need to get a laptop for using with a projector. Now I'm pretty sure that just about all laptops will do a dual output - so I can have an image on the laptop screen and on the projected screen.
I'm assuming it's better to have a dedicated graphics card rather than an onboard shared memory card, but wondered if anyone had any thoughts on general suitability?
Not a huge budget and was looking at something like this http://direct.tesco.com/q/R.204-5614.aspx
Cheers
Cheers
3 REPLIES 3
Re: Laptop for projector
21-09-2009 12:29 AM
Should be fine - the dedicated graphics would be helpful obviously (that ati in there looks fine)
I Know for a fact that vista settings allow Dual Monitors - Either as a clone (which you'd want im assuming) OR as two seperate entities - good if you have things on your screen which may be slightly personal - or you just dont want them seeing?
The outputs should be ample for supporting a projector (vga) or a large flatscreen TV (hdmi)
hope that helps =]
hope that helps =]
21-09-2009 12:33 AM
i wouldnt buy just yet-
http://www.ebuyer.com/product/173591
This looks much better imo for the same price 😉
edit:
http://www.ebuyer.com/product/155558
Incase you wanted to move away from AMD/Acer - my personal preference to the first i posted.
edit:
21-09-2009 7:32 AM
No it'd be 2 separate entities that I'd want, though I have the software to control that.
