Laptop for Linux
- Laptop for Linux
Re: Laptop for Linux
04-02-2009 1:47 PM
Quote from: poppy Seems weird not having the AV though (and all the other security stuff).
AV may be required in some circumstances. https://help.ubuntu.com/community/Antivirus
Here is some information re firewalls. https://help.ubuntu.com/8.04/serverguide/C/firewall.html
04-02-2009 1:51 PM
To get networking running I followed the script in message #7 here: (I don't know if this will help in your case but perhaps worth a look)
http://ubuntuforums.org/showthread.php?t=846271
To enable wpa2 in wicd:
Click on the triangle to the left of the displayed SSID
Chose Advanced Settings
Check Use Encryption
Chose encryption method from drop-down list and enter key
Click OK
04-02-2009 4:15 PM
iwlist scanWill show local networks, channel they're using, signal strength etc...
iwconfigshows info about your wireless network.
04-02-2009 4:23 PM
At least I have Internet access but it would be good to solve the problem. Wouldn't have got this far without all the help and support so a big thank you to all.
04-02-2009 4:42 PM
Caution:- there is a lot of security info embedded here
04-02-2009 5:47 PM
I can also enter Network Connections and this has the wireless tab.
Have had a scout around and will continue to look but could you please post back and point me in the right direction for the file you mentioned?
Apart from the irritation of not knowing what's up, I was wondering if it would be better to scrap this installation and purchase a used laptop solely for Linux. Not just because of this problem, but Ubuntu has taken up 10GB of the 11GB partition so I haven't much room for manoeuvre. However, apart from this minor irritation, I am finding my way about. Just missing the start up menu because I parked all my shortcuts on there in Vista. I guess it will take quite some time to get comfortable with it.
04-02-2009 5:54 PM
Im hoping that when you said previously that the card was an Sis1634 it was a mistype and its really an sis163u because I cant find much about the 1634 but plenty about th 163u relating to Siemens laptops.
Hopefully this post https://wiki.ubuntu.com/LaptopTestingTeam/FujitsuAmiloLi1818 will help. It describes your problem in that Network manager doesnt run because the driver isnt loaded. At the bottom of the post it gives step by step details on how you use ndiswrapper to load the windows driver.
Hope that helps.
Ian
04-02-2009 6:21 PM
In view of the fact that I am thinking that a laptop just for Ubuntu might be the best way to go, we are checking the want-ads and have found a few possibilities.
This has been a useful experiment as I now know about the OS and if I have a designated machine I know that I won't need to worry about messing up the Vista installation.
Also, I haven't much space for the updates that are offered. Would this be the best way to go?
BTW the model is the AmiloLi1818.
04-02-2009 6:26 PM
04-02-2009 8:04 PM
Quote from: axisofevil To see what's around use terminal (Applications, Accessories) iwlist scanWill show local networks, channel they're using, signal strength etc...iwconfigshows info about your wireless network.
oddly enough iwlist scan on my install only shows my active connection, I have a shed load more in the little gnome applet
04-02-2009 8:06 PM
04-02-2009 10:13 PM
alternatively, you can install to a usb key.
you seem to be doing pretty well so far. keep slogging away, you'll get there.
05-02-2009 7:27 AM
This sounds better than another laptop and much cheaper.
BTW thank you for the encouragement but couldn't have got this far without all the help/support here.
05-02-2009 7:58 AM
i prefer to install to an external drive, rather than flash, because i can put a swap drive on the external. it's not advisable to put one on flash drive as it wears them out too quickly, they having a limited write cycle. a 2.5" drive is small enough to carry about and boot on anyone else's machine that will boot from usb. 40gb would be ideal, divided up as 2gb for swap, 10gb for / and the rest for /home.
before going further, get into your bios and confirm that you can boot from usb. then you can decide which route to go.
05-02-2009 8:55 AM
Quote poppy, you can install linux to an external usb drive. so long as the bios on your computer allows booting from usb devices, you may be able to save yourself a bob or two.
Nice one , I didnt even think of that, but when you think about it, what a neat idea...
