Laptop batteries
- Re: Laptop batteries
Laptop batteries
11-02-2013 7:45 PM
Seriously - I've been asked this - I don't know the answer.
11-02-2013 7:48 PM
11-02-2013 7:51 PM
11-02-2013 7:53 PM
11-02-2013 9:39 PM
you just remembered it`s got no battery !.....
11-02-2013 11:18 PM
Must buy one one of those ANY key things...
12-02-2013 12:41 AM
Generally, when connected to mains, the battery is bypassed/recharged while in use, however, some systems are always powered by the battery, and the mains keeps the battery charged.
The easiest way to determine if it'll work is to remove the battery and try.
13-02-2013 4:35 PM
One thing to note though is that the charging sockets can be a bit fragile and can wear out pretty quickly so you may want to consider using a battery anyway and just charge it when needed instead of relying on it.
13-02-2013 4:47 PM
Quote from: vilefoxdemonofdoom Does a stationary laptop need a working battery to run properly?
Our 4 year old Samsung has an absolutely dead battery attached to it. We run it just on the adapter. If we pull the lead it dies immediately - no blinks, no power down, no nothing.
It's been running like that for some months now.
We've never tried running it without the battery as I read somewhere sometime ago that some laptops have the charging circuit built into the battery. No point in risking it as it runs perfectly well with the dead battery attached.
York.
13-02-2013 5:10 PM
13-02-2013 6:28 PM
I was thinking about buying a replacement battery, then decided to open it up, and inside is some special size (like oversized AA ) rechargable batteries.... got some i.d. from them , googled them and was going to buy 6 to fit myself.... then I saw something on Youtube about putting the battery inside two poly bags wrapped in a teatowel and into the Freezer for 48 hours.... bring out , let them "thaw out " for a couple of days... put in laptop, and hey presto supposed to charge up again.....
didn`t work for me... but I used to leave the laptop in the car, unused for days at a time, and last winter (not this one just happening). it was a week before I plugged in the laptop to use... LO!. and Behold... it started to charge again... and... although it did not fully charge... showed a full charge and would work for about half an hour when disconnected from the mains....
