Laptop Speakers
valart
Laptop Speakers
I have a Toshiba laptop I listen to a lot of music and I am plugged in to my own speakers which is plugged into the headphone jack,is there a way where I can mute the laptop speakers and just have sound from my external speakers.
1 REPLY
Fixes: 20
Re: Laptop Speakers
How are you connecting your "external speakers" ?
If you use the Phone jack, it should mute the speakers, in the same way as when you put a pair of phones in.....
