Laptop Screen Clean
Laptop Screen Clean
A quick question please. What's the safest way to clean the screen on my laptop?
VileReynard
Seasoned Pro
Fixes: 9
Re: Laptop Screen Clean
With a specialist screenwipe!
dick:quote
i use warm boiled water, a soft tissue and a gentle touch.
pierre_pierre
I have just been using one that was sold as  Plasma and LCD TV  screen cleaner, it got rid of finger print no problem.
get a small pack as the tissues can dry out..
Can i swear, got mine fron Tesco's
I have two clean yellow dusters - one damp, one dry. I gently clean the television and computer screens with the damp duster and finish off with the dry one. No problems so far. Wouldn't bother with the specialist wipes - waste of money.
PS Obviously, screen needs to be cool.
Fixes: 116
I use a microfibre cloth and the threat of bodily damage if anyone touches my screen Wink
Will Moderate For Thanks
Fixes: 50
Quote from: artificer
That's what was recommended to me and it worked fine.
Customer and Forum Moderator.
Isopropyl alcohol solution (the liquid you would get in a cd cleaning kit)
Some good suggestions guys, thank you.  When I get home next week the laptop will need a good spring clean Smiley
scootie
elbow grease  Smiley .
i use the special blue colth i got with my samsung lcd tv. i soon learnt why they gave a cloth with it wen the sexy black souround started to atract dust from 100 yards away
fceluk
I know exactly what you mean Asbo and if you get their 'home cinema' to go with it it gets a whole lot worse Angry
VileReynard
Seasoned Pro
Fixes: 9
Screenwipes can be found at all good stationery cupboards. Grin
mikeyd
I guessed someone would find that Grin Grin
Yes, but the little dog only cleans the inside!
