LTS
LTS
27-11-2013 3:44 PM
Re: LTS
27-11-2013 4:00 PM
Generally most mint releases ( or any distro ) are supported until the next release, which in the case of ubuntu based distros can be every 6 months.
LTS releases are supported for longer periods.
eg Linux Mint 13 Maya is supported until April 2017
As to more stable, like any software the longer it is supported, the more chance there is of the developers ironing out any bugs, but LTS distros don't always have the latest versions of software
Re: LTS
27-11-2013 4:35 PM
But its such a pain reinstalling Mint that I would wait a few months and you can install 14.04.
Re: LTS
27-11-2013 6:09 PM
Quote from: vilefoxdemonofdoom But its such a pain reinstalling Mint that I would wait a few months and you can install 14.04.
HOW?
You can do an ubuntu style upgrade but it is not recommenced.
I installed 16RC in a separate partition for testing, about 15min needed to install, then test - days ...
Upgraded my M15 install by backing up my important bits (for me) fstab, my repository list and a few shell scripts to install stuff.
Fresh install, keeping my /home partition took 15 min, re-installing all the s/w took about another hour.
LTS can be thought of as good for those who like a stable system and don't want to update/upgrade regularly. You will get all the important fixes but not necessarily the latest versions of the apps. Me I prefer the clean and re-install every 6-8 months, but I have Mint Debian Edition on my laptop so I can just leave it running 24/7 and it is still up to date. (Rolling release)
Re: LTS
27-11-2013 9:09 PM
would I notice any user interface difference?
It's important that other family members don't have anything to whine about.
Having the latest, greatest program version isn't important.
Actually - I just found the answers to those questions!
I have several bits of software which may not be Ubuntu but are "Ubuntu compatible"
also I have a couple of PPA's which would need to be supported.
Quote LMDE in brief
Linux Mint Debian Edition (LMDE) is a semi-rolling distribution based on Debian Testing.
It’s available in both 32 and 64-bit as a live DVD with MATE or Cinnamon.
The purpose of LMDE is to look identical to the main edition and to provide the same
functionality while using Debian as a base.
but...
Quote FAQ
1. Is LMDE compatible with Ubuntu-based Linux Mint editions?
No, it is not. LMDE is compatible with Debian, which isn’t compatible with Ubuntu.
Quote 4. How does LMDE compare to the Ubuntu-based editions?
Pros:
You don’t need to ever re-install the system. New versions of software and updates are continuously brought to you.
It’s faster and more responsive than Ubuntu-based editions.
Cons:
LMDE requires a deeper knowledge and experience with Linux, dpkg and APT.
Debian is a less user-friendly/desktop-ready base than Ubuntu. Expect some rough edges.
No EFI, GPT or secureBoot support.
Re: LTS
28-11-2013 9:36 AM
What ones do you need, or try it in a VM.
LMDE with Cinnamon should be the same as LM 13 might even have the newer CInnamon (v2)
Re: LTS
28-11-2013 11:11 AM
Also my printer driver seems to be RPM based - so that must work to.
I don't use Wine - but I can use Dropbox to communicate with a tiny Windows 7 partition on a switched off netbook.
Does LMDE use Nemo - I don't like Nautilus (any more)?
Since it's impossible (in practice) to start a new /home, I think I will need to wait until I get a
new PC - which is likely to be a long time.
Re: LTS
28-11-2013 11:31 AM
I have all the partitions with their own /homes for testing. Or if I want to use the real /home I add a different user.
Printer driver no difference, just install alien.
Dropbox no issues, install from the deb from the web site.
Nemo is standard on Cinnamon I think?
WRT Latex I think it is already in Debian. See this https://www.tug.org/texlive/debian.html
Re: LTS
28-11-2013 2:49 PM
There are 75,000 files (not counting cache entries)!
(system wide and default preferences are in the /etc directory of course).
Since /home contains 4 users each with different preferences, I think that migration to LMDE may prove impossible.
So I would (probably) need to run two parallel Linux systems, each with their own /usr, /etc, /home...
I'll try a DVD trial of LMDE though.
Re: LTS
28-11-2013 3:20 PM
700K files in it, thats files not the size
As to different users, note their user_id's and recreate them with the same id and it should be fine.
Re: LTS
28-11-2013 5:46 PM
Re: LTS
28-11-2013 5:48 PM
Re: LTS
30-11-2013 5:58 PM
I shall be replacing everything but my /home
My partitions are currently a bit scattered
so I shall be moving my /home so it's a bit nearer (physically) to /usr etc
Such fun.
Re: LTS
01-12-2013 10:52 AM
Good luck with the test. Back up your app list first and copy the /etc folder to some where so you can see what extra's you setup.
Re: LTS
01-12-2013 1:22 PM
/video (about 700GB)
/home (about 200GB)
So I get lots of head movement on my 1TB disk.
I don't usually bother backing up /etc - just things like passwd, fstab and crontab's
/etc seems like a good idea anyway.
