LAN setting prevents me from accessing internet?
paulo
For no apparent reason my PC would not connect to the net after a long period of no problems in respect to this. After a bit of research I decided to check LAN settings (Internet options/Connections/Lan settings) Mine was set to 'use automatic configuration script' I unticked the box and was able to connect to the net and surf quite normally.
Next time I booted the PC I could not connect again and found the box had been ticked again. I do not understand the LAN setting so need some help.
1, Lan setting have 2 options ie 'automatically detect setting' and 'use automatic configiration script'. Which should I be using if any?
2, Why has this issue suddenly started to give me problems?
3, How do I make the PC retain the correct setting when I reboot? (switch on the PC)
I can resist everything except temptation.
12 REPLIES 12
Oldjim
Resting Legend
Fixes: 63
Re: LAN setting prevents me from accessing internet?
which operating system are you using - and if windows 7 have you just installed SP1
ReedRichards
Seasoned Pro
Fixes: 25
"Automatic configuration script" is an option I have never seen used on a home computer.  Possibly on a corporate network?  If the setting reappears then either it is set by some sort of policy or there is another program (malware?) tampering with your settings.
paulo
Yes should have said, am using XP Pro and IE.      Have done deep scan both up to date Zonealarm (paid-up version) and also SuperAntivirus.
Always connected fine for years and this problem started out of the blue recently.  No setting have need changed (by me, soul user)
Oldjim
Resting Legend
Fixes: 63
ReedRichards
Seasoned Pro
Fixes: 25
It looks to me that "SuperAntivirus" is malware, so I hope you meant "Superantispyware".
pierre_pierre
the google search for that program is weird
How to Remove Super Antivirus Malware From a PC | eHow.com
How to Remove Super Antivirus Malware From a PC. Malware such as Super Antivirus Malware can harm your computer by damaging important files and documents.
www.ehow.com › Computer Software - Cached
super antivirus downloads - Free software downloads and software ...
Find super antivirus downloads at CNET, the most comprehensive source for free-to-try software downloads on the Web.
download.cnet.com/1770-20_4-0.html?query=super+antivirus... - Cached
Super Antivirus
I am very happy with Search And Destroy super antivirus because it offers the protection I need at a price I can afford. I made a big investment when I ...
www.scribd.com/doc/10407363/Super-Antivirus - Cached - Similar
Super Antivirus 2010 by Next
23 Sep 2010 ... Super Antivirus, has a growing large database, 700 viruses. Scripts for cleaning hiden or system viruses. bats, fro cleaning the temp and ...
https://www.planet-source-code.com/vb/scripts/ShowCode.asp?... - Cached
Just downloaded and finished scanning with super antivirus and ...
20 Nov 2010 ... i downloaded and waited 1 hour for the scaning to complete, ... There is no such known program as super antivirus. enough said. ... Last time I had ...
uk.answers.yahoo.com › ... › Computers & Internet › Security - Cached
Get more discussion results
I need to know the official site to download superantivirus ,virus ...
19 Feb 2008 ... official site to download this antivirus called ...
answers.yahoo.com › ... › Security - Cached - Similar
Our computer tech put SUPERAntivirus Spyware Free Edition and ...‎
Is there such a thing as superantivirus or superantimalware from ...‎
Does the product called Superantivirus Spyware work as well as it ...‎
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: pierre_pierre
the google search for that program is weird....
I am very happy with Search And Destroy super antivirus b............
I think this is mostly misinformation.  "Search and Destroy" is clearly stolen from "Spybot Search and Destroy" and there is no concrete link that suggests a legitimate program called "Superantivirus" exists.
fourfourdevon
SuperAntivirus is not a legitimate program, and running it with other antivirus installed could quite easily be making those program (the real ones) give you false all clears.
You need to reinstall your PC from scratch.  Make sure you back up and documents, pictures etc first.  And when you've reinstalled your machine, the first thing you should do afterwards is use your Zonealarm to check all the files backed up to make sure they don't have any virus's etc.
pierre_pierre
I dont like Norton but it gave superantivirus.com and super-antivus.com both clean, but another one superantivus 2010 is a rogue
paulo
Quite right ReedRichards I did mean SuperAntispyware so no panic folk.    Sorry I may have also caused this thread to go off topic by my mistake!!
At the mo I am studying the links Oldjim gave.
paulo
Many thanks Oldjim you came to my rescue again and came up trumps.
Solved the problem using the method in your second link.
Thanks all for your contrbutions to this thread.
paulo
Spoke too soon.  On rebooting this morning the problem has re-accured even though I have
          'Disable caching of auto-proxy scrips'  Enabled.      (See Oldjim's second link above)
Something else must be overiding this setting.
Any more ideas?Huh
