Kindles
deekay
Kindles
I am considering buying a Kindle and I have a query which will show my complete ignorance regarding them!
Can I install stuff on them myself? If, for example, I get a computer program and its manual is on a CD, can I transfer this manual to the Kindle? Printing a 50+ page manual would cost me a fortune in printer ink!
I have Googled, but can't find the answer.
Many thanks for any help.
Keith
12 REPLIES 12
Strat
Fixes: 565
Re: Kindles
I have a manual in pdf format loaded onto my Kindle and it reads fine.
Simply connect the Kindle to the PC with a USB cable and drag and drop the file into 'Documents' on the Kindle.
Customer and Forum Moderator. Windows 10 Firefox 105.0.1 (64-bit (64-bit)
deekay
Re: Kindles
Thanks very much for your reply, Strat.
It's good news and I will defininately get a Kindle ASAP.
Cheers
Keith
Fixes: 260
Re: Kindles
You can also email personal documents to your Kindle http://www.amazon.co.uk/gp/help/customer/display.html?nodeId=200767360 .
Strat
Fixes: 565
Re: Kindles
For a small fee.
shalom2010
Re: Kindles
@Strat
It actually free:
"You can also send your personal documents via e-mail as attachments to [name]@free.kindle.com. To have a document converted to Kindle format (.azw), the subject line should be "convert." Kindle Personal Documents Service will attempt to deliver your personal documents to your Kindle device via Wi-Fi when connected, and to the e-mail address associated with the Amazon account to which the device is registered. You can use the e-mail to download the file to your computer and transfer it to your Kindle device using a USB connection."
http://www.amazon.co.uk/gp/help/customer/display.html/ref=hp_kin_200767360_pdoc_lmsend?nodeId=200767...
I've used this service for the last two years! The program 'Send To Kindle' is worth downloading (http://www.amazon.com/gp/sendtokindle) as you just right click the document/s to send to your free amazon address & after a few minutes it's ready to download to your Kindle.
Fixes: 260
Re: Kindles
For a small fee.
Yes, I thought that Strat, but you only pay if it's delivered over Amazons 3g network.
Strat
Fixes: 565
Re: Kindles
Thanks guys, that's useful to know Smiley
gleneagles
Aspiring Legend
Fixes: 17
Re: Kindles
Shalom2010,
Some good links there, Thanks.
We are born into history and history is born into us.
deekay
Re: Kindles
Thanks for all your replies.
There is some very useful information you have given
Cheers
Keith
logan47
Re: Kindles
Sometimes I  find ebooks in the .EPUB format which the kindle does not read. A nice little program to convert them to .MOBI ( kindle format) is, Calibre, ebook manager and converting tool. Well worth using. It's got a lot in it but I only really use it to convert other formats to kindle Mobi.
Linky if interested.  Smiley
http://calibre-ebook.com/
shalom2010
Re: Kindles
I was using Calibre but much prefer http://www.hamstersoft.com/free-ebook-converter/ - it's tiny in comparison & far easier to use (and quicker too!)
PeeGee
Re: Kindles
Unfortunately, adding WINE just to run it results in 4x the space for calibre Roll_eyes Cry
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
