Kindle Fire
- Re: Kindle Fire
Kindle Fire
01-11-2013 6:40 PM
Re: Kindle Fire
01-11-2013 6:48 PM
Re: Kindle Fire
01-11-2013 7:23 PM
Re: Kindle Fire
01-11-2013 7:35 PM
Quote from: MisterW I'd consider the Hudl from Tesco, same price but better spec and not 'amazonised'
I would concur with this, if you buy a Kindle Fire, you are saddled with exclusively buying Kindle books and/or apps from Amazon, whereas with the Hudi, you can buy apps from anywhere, even Amazon (I think)
Re: Kindle Fire
02-11-2013 10:18 AM
Re: Kindle Fire
02-11-2013 2:07 PM
So you could download from various sources to your computer, convert and then transfer to your Kindle ?
Re: Kindle Fire
02-11-2013 2:21 PM
Re: Kindle Fire
02-11-2013 2:30 PM
The bottom line though is that hudl has a much better spec for the same price.
Re: Kindle Fire
02-11-2013 2:58 PM
Re: Kindle Fire
02-11-2013 3:08 PM
Re: Kindle Fire
02-11-2013 3:33 PM
I would look at the Hudl as mentioned or the Nexus 7. If you want to read books, etc. there is the Kindle app on the Play Store, along with other similar apps.
Re: Kindle Fire
02-11-2013 5:35 PM
