Keys strokes not repeating [Solved]
- Keys strokes not repeating [Solved]
01-10-2014 1:09 PM
I know I have had this issue before and have searched but can't find anything
No key can can be repeated until another is pressed whether it be numerical, letter, backspace/delete or cursor control.
I have Logitech SetPoint installed and have looked at both its and Control Panel's setting but nothing obvious shows up.
Can anyone remember the previous thread where I am certain I found a resolution?
It's not a eatery issue as they are recently new at insertion and the software indicates there is still a lot of life left in them.
A bit more delving and a brainstorm meant I found that Filter Keys in Ease Of Access Centre had been turned on.
No the next question is ... how?
Forum Moderator and Customer
1 REPLY 1
Re: Keys strokes not repeating [Solved]
01-10-2014 1:26 PM
Shift for eight seconds Turn Filter Keys on and off
Windows logo key +U Open the Ease of Access Center
