Key finder
30FTTC06
Fixes: 4
Key finder
Need a win vista key-finder for my pre-installed vista. anybody got any safe Suggestion please ?
7 REPLIES 7
HPsauce
Re: Key finder
Magical Jellybean.
Strat
Fixes: 565
Re: Key finder
Belarc Advisor http://www.belarc.com/free_download.html
I've also used Jellybean a lot and found it to be effective.
Mav
Fixes: 510
Re: Key finder
+1 for Belarc Advisor.
Forum Moderator and Customer
30FTTC06
Fixes: 4
Re: Key finder
Many Thanks all.
I'm just hoping it will catch the key for ms-office s well with a bit of luck Smiley
Strat
Fixes: 565
Re: Key finder
Jellybean found the key for a copy of Office 2007 I have removed and lost the key to Undecided Cool
rongtw
Fixes: 12
Re: Key finder
jellybean  Cool
30FTTC06
Fixes: 4
Re: Key finder
Thanks again, both of these key finders found the o/s and office keys that i needed for a fresh install, although i think on sheer info alone Belarc Advisor wins it for me. If i was just looking for a windows key quickly i think i would use jellybean. Either way, both work fine.
