Keen Kaspersky
Fixes: 86
Keen Kaspersky
I have just renewed my subscription to my Kaspersky Internet Security package online.
I received 2 emails, one with an attached invoice and another with the renewal key.
Both emails were caught and quarantined by my Kaspersky. Roll eyes
Is this a case of tunnel vision or what!!!
Customer and Forum Moderator.
Re: Keen Kaspersky
You're not alone there, I quite regularly have Spy Doctor updates "caught" in it's scans. Most AVG updates are also are also given the same treatment by SD. I just found it rather more amusing rather than serious.
Fixes: 86
Re: Keen Kaspersky
I always find these sorts of situations highly amusing...
A bit like policemen being arrested for speeding by policemen Roll eyes
