Kaspersky Win 7 Cock–Up?
- Kaspersky Win 7 Cock–Up?
- « Previous
- 1
- 2
- Next »
Re: Kaspersky Win 7 Cock–Up?
13-10-2009 6:14 PM
Still, 9 more days till Win 7 comes out, I really should consider starting to back up all my stuff before the clean install.... maybe later.
13-10-2009 7:53 PM
Quote I really should consider starting to back up all my stuff before the clean install.... maybe later.
Spent several hours at the weekend doing just that - boring but necessary.
Still got a few more last minute bits and pieces than ready for upgrade and hoping that it all goes OK.
Will check the Kaspersky forum and might put Avast on as a temporary measure if Kaspersky 2010 is still causing problems.
19-10-2009 7:41 PM
seems to be OK up to now on Windows 7 RC and accepts a commercial key
20-10-2009 10:33 AM
Wondered what the parcel was as the release date is meant to be 22nd October 2009 - PCW must be trying to beat the potential postal strike. Will wait for Kaspersky to release the final compatible version before installing, although it is tempting to use the link above.
20-10-2009 10:58 AM
20-10-2009 11:03 AM
20-10-2009 11:11 AM
One thing which is causing a slowdown problem on my system is the number of hidden files in the Vista boot partition (scan running under Windows 7)
21-10-2009 6:12 PM
21-10-2009 6:25 PM
21-10-2009 6:54 PM
23-10-2009 12:23 PM
- « Previous
- 1
- 2
- Next »
