Kaspersky Password Manager
Strat
Fixes: 565
I use Kaspersky AV and find that Password Manager is included, so the other day I installed it.
One of the menu options is to import user-names and passwords from various sources including my Firefox browser.
I did this and soon noticed a number of 'dead links' with user-names and passwords.
In Firefox 'Logins and passwords can be easily edited and/or deleted.
So I looked for the same in Password Manager.
Does anyone use Kaspersky Password Manager and knows how dead entries can be removed.
Some of the 'dead links' are NAS drives that were equipped with an IP, a username and password.
These drives are no longer available.
13 REPLIES 13
shutter
Fixes: 65
Re: Kaspersky Password Manager
Interesting, that you should give your passwords to a Russian company  !   ? ? ? ?
Strat
Fixes: 565
Remember the old saying 'never judge a book by it's cover'.
Thank you for your contribution @shutter
Strat
Fixes: 565
I've decided to uninstall the Password Manager until such time as I can find a solution or give up. 😞
Fixes: 1,483
I can heartily recommend 1Password if you want a good password manager Smiley
Legend
Fixes: 255
@Strat Sorry, I missed this, even though it is 'Latest topic'. You use Firefox don't you? There's a password manager installed on that, and it creates unique passwords (for most sites) - super-secure, like finance seem to block it in favour of their own systems, though.
Strat
Fixes: 565
Thanks @dvorak.
The reason I chose Kaspersky Password Manager was because it is included in my Total Security package.
Maybe I will give it another go with the benefit of hindsight.
Strat
Fixes: 565
Thanks @jab1
Yes I do use Firefox and its password manager but I've just left it to do its stuff.
They seem to have made some improvements.
People seem not to like password managers built into browsers.
However any app you care to mention has its detractors.
So I will flip a coin.
PS One big advantage that Firefox password manager has over the Kaspersky offering is that redundant entries can be deleted 😎.
Legend
Fixes: 255
OK @Strat . I think it has vastly improved over the last couple of major upgrades, and as I can sync it between the laptops, iPad and iPhone, it saves having to remember which machines I haven't changed PW's on. I also use a master PW, so even if I did lose the Apple devices, it is  still secure.
Fixes: 395
@Strat  I use keepass , its cross platform so works on my Windows, Linux and android devices
Its open source gpl , so you can inspect the source if you want to
https://keepass.info/
Review here
https://www.safetydetectives.com/best-password-managers/keepass/
Fixes: 419
I use Keepass which I have installed on a USB memory stick. When not in use it is unplugged and kept in a safe place away from computers. Consequently there is nothing stored on my PC.
Legend
Fixes: 255
Another good option, @Baldrick1 , and I may consider that option as a third line of defence. Will it pick up previously created credentials?
I'm not too bothered about what is stored on the current equipment - it is all password/fingerprint access protected, so unless it was stolen by someone with a reasonable idea of how to bypass all that, they wouldn't get far anyway.😉
Strat
Fixes: 565
Thank you @MisterW  and @Baldrick1
That is a very interesting option.
ITWorks
Fixes: 9
Another option you may wish to look at @Strat is BitWarden  i have used it for a few years now , it is multi platform , open souce , has paid and free versions ( for most people free will be fine)
I have found it to be very good
