Just bought a new Canon Pixma printer/scanner, help!
Minivanman
Legend
Has anybody here bought one of these as mine is driving me nuts.
For some reason it will only scan images as a PDF file which means I cannot edit the image in any way. The first time I tried to do this it was fine but now......
Guess I'll just have to read that manual if nobody knows!
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
8 REPLIES 8
Mav
Fixes: 515
Re: Just bought a new Canon Pixma printer/scanner, help!
Have you tried scanning direct to a third party program like irfanview?
Forum Moderator and Customer
Minivanman
Legend
No I've not Mav, but then I shouldn't have to?
Herman Melville
Oldjim
Resting Legend
Fixes: 63
which model
Minivanman
Legend
Pixma MG2450 Cool
Herman Melville
Oldjim
Resting Legend
Fixes: 63
I can't help really but one possibility is that you are using the Copy Function rather than Scan
A quick check - you probably need to select Custom Scan to change it
SpendLessTime
Fixes: 86
Easy to do (Pixma 3120)
using Canon MP Navigator EX free software
Click the "Save to PC" icon
Change "Save as type" to JPEG/Exif  or TIFF or BMP
Choose the other options to suit and you are away.
Minivanman
Legend
OK thanks, although no setting have be either accessed or changed by myself.
Will have a look, cheers.
Herman Melville
Luzern
Fixes: 9
When the scanned file appears, go to top l/h corner of screen, and click on Save. You can scroll down dialog box and choose other image file formats. If you want something like Word or Excel, an online converter may be an answer.
Memory fades quicky, but I cannot recall that with older Canon scanners the output choice being wider. BTW my model is MG6850.
