Jersey wifi hot spots
- Jersey wifi hot spots
13-03-2009 10:19 PM
Googling doesn't present many options, so wondered if anyone had URL for good list of wifi hot spots in Jersey?
5 REPLIES 5
Re: Jersey wifi hot spots
14-03-2009 9:02 AM
just tried my sat nav data base on the internet total of 9560 places, Orange, T mobile, The Cloud, BT Openzone, plus three others nothing, although the Scilly Isles have T moblie :'(, just a thought didnt look at France, gone to have another look, had anothe look nothing
14-03-2009 2:55 PM
PP: Thanks.
I see there's one McDonalds there which hopefully is wifi equipped.
14-03-2009 3:03 PM
It was about 6 years ago when I went there, and I had to roam off their mobile network.
In case you don't know, you don't get the usual UK operators there (still the case I think), and Jersey Telecom has somewhat of a monopoly.
Found this to start with:
http://www.jerseytelecom.com/templates/LayoutB.aspx?id=1383
14-03-2009 3:10 PM
14-03-2009 3:22 PM
There are a couple of FON spots in St Helier http://maps.fon.com/#
