Javascript being progressively removed in browsers - or is it - it isn't see accepted fix
Oldjim
Resting Legend
Fixes: 63
At least in Microsoft Edge and I wonder when or if  the others will do it
Why am I bothered - because the two websites I look after both using Wordpress have the email addresses munged using javascript and one of them uses Jetpack which also appears to need javascript
14 REPLIES 14
shutter
Fixes: 65
Re: Javascript being progressively removed in browsers - or is it
I got a "popup" notice saying there was a Java update.... tried it... but it kept failing.....  running latest version of FIrefox 64 bit...
I seem to remember from some time back something about FF not supporting Java any more on new(er) updates...
Can`t say I`ve had any problems...
Oldjim
Resting Legend
Fixes: 63
Java is different and is blocked - I am asking about javascript
VileReynard
Fixes: 20
Virtually all web sites use Javascript, so its tough luck if you are forced to use a defective browser.
chenks76
All Star
Fixes: 12
you've made the mistake of assuming that java is the same as javascript, which it isn't.
schoolboy error.
chenks76
All Star
Fixes: 12
all browsers have the ability to disable javascript, but that option is always turned off by default, because as has already been said, enabling it would make 99% of websites useless.
if Edge is forcing it on then stop using Edge.
Oldjim
Resting Legend
Fixes: 63
I don't use it but the question was in relation to my websites
pjmarsh
Fixes: 20
Where have you found that?  Edge has increased its Javascript compatibility with each update so far, and I've not heard of that stopping.
Oldjim
Resting Legend
Fixes: 63
From numerous searches and it appears that it was all rubbish as I just tried my two sites using Edge and - guess what - it all worked Shocked Shocked
7up
Fixes: 17
Must be said I would be a bit shocked if such a drastic change happened so quickly like that.
shutter
Fixes: 65
@chenks76
schoolboy error.
Yeah, well...... we ain`t all super computer techies.... that`s why I ask for help on here sometimes...
realisiticlally, I haven`t a clue what Java or Javascript do... to me, it s just something that is on the computer, and does something on something else, and my computer works.   do I really need to know more than that ?  if so, perhaps you will be kind enough to give me some private tuition.
chenks76
All Star
Fixes: 12
You couldn't afford it
VileReynard
Fixes: 20
https://en.wikipedia.org/wiki/JavaScript
https://en.wikipedia.org/wiki/Java_(programming_language)
Java is the one with thousands of bugs in it.
shutter
Fixes: 65
With an attitude like that,... I wouldn`t want to be taught by you.
chenks76
All Star
Fixes: 12
i keep my prices artifically high to keep away the riff-raff.
it works a treat.
