Java
oldbaldeagle
Java
The 'Update' tab has disappeared off the Java control panel on my daughter's laptop.  I've had this issue before & found a straightforward process on Google to correct this; this time around I can't find the answer on Google.
Any advice would be gratefully received.  The laptop is running 64bit Windows 7.
5 REPLIES 5
oldbaldeagle
Re: Java
Solved it - Start/All Programs/Java/Check for Updates.  The Update tab is now back on the Java Control Panel.  Smiley
rongtw
Fixes: 12
Re: Java
Do people still use Java  Huh
i dont have it installed and i have no problems
Anotherone
Champion
Fixes: 21
Re: Java
You don't use pingtest.net then  Wink
rongtw
Fixes: 12
Re: Java
nope  Wink
speedtest  Cool
Anotherone
Champion
Fixes: 21
Re: Java
Don't always get reliable pings from there Wink  still, it's usually better than the BT Speedtester  Grin
