Java - new zero day vulnerability - new release Java 7u11
- Java - new zero day vulnerability - new release Ja...
11-01-2013 9:59 AM
Now the really interesting part for me is I use Firefox with the fully up to date version - and Firefox has disabled it by itself
Quote A new Java zero-day security vulnerability is already being actively exploited to compromise PCs. The best way to defend against the attacks is to disable any Java browser plugins on your systems.
The offending bug is present in fully patched and up-to-date installations of the Java platform, now overseen by database giant Oracle, according to Jaime Blasco, head of labs at security tools firm AlienVault.
Re: Java - new zero day vulnerability
11-01-2013 10:04 AM
Do (m)any websites actually still use Java applets these days?
11-01-2013 10:10 AM
Quote from: Oldjim I use Firefox with the fully up to date version
I'm running Java(TM) Platform SE7 U9 10.9.2.5
11-01-2013 10:18 AM
So once disabled it stays disabled for ever unless a new version is installed by a third party and then both versions seem to be there
11-01-2013 10:19 AM
11-01-2013 10:22 AM
I also did a reinstall 2 days ago and running it again it shows as being up to date
11-01-2013 10:58 AM
Quote from: jelv I think you need to go through the total removal of Java procedure and start again.
Did you do a full Java uninstall first? http://www.java.com/en/download/uninstall.jsp
11-01-2013 11:02 AM
Also removing JavaFX as I have no idea where that came from
11-01-2013 12:16 PM
The most difficult needed a dll delete having found the source using about:plugins but the worst was a blocked uplay plugin which was really well hidden (it was in the ubisoft directory and wasn't listed in the about:addons list)
11-01-2013 3:36 PM
11-01-2013 7:02 PM
11-01-2013 7:59 PM
I use the following website quite a lot......
http://www.ship-tracking.co.uk/Main%20Menu/
click on SOLENT in the first box ( AIS MAPS )..... and the solent and I.o.W map appears, then the ships positions appear, then the map disappears.....
I reported it to the web owner, who advised me to disable the Jave cache.... and it cured the problem..... that was this morning.....
been off out all day, and just tried it again.... and the map disappears... so it looks like Firefox has done the deed again, and disabled Java.....
Reported to the website owner, just now, with a linky to this thread....
12-01-2013 9:43 AM
http://www.ship-tracking.co.uk/AIS%20Maps/solent.html
The background map disappears for me..... Website owner also uses FF, he said it reported Java shut down... but he still sees the map as a background to the ship positions as normal....
12-01-2013 9:56 AM
12-01-2013 10:02 AM
The map works fine regardless of Java. I think the only problem was it once scrolled itself to the bottom of the page, where there is a big empty space, but I could not repeat that.
