Java and Win7 - cured at last
pierre_pierre
I am having repeated failures trying to get Java to install, Think I have got Java jre installed, but the BT Speed test is reporting no Java,  I have Avast and M$ firewall, keep getting the message below
Fixes: 62
Re: Java and Win7
Have a look in Add Remove programs - it may already be installed in an earlier version. If so remove all versions and start again
pierre_pierre
Re: Java and Win7
just found this
java.com type in your error or find a removeruninstaller.
    * 8 hours ago
Sorin by Sorin
    November 21, 2009
This only happens in Vista, so I am going to assume you are using it. The reason for not working for vista is that the jre msi location has been moved recently from \\users\username\Appdata\Local\Sun\Java\… to \\users\username\AppData\Local\Temp\Low\… during some bug fix. I just found out that the "Low" folder in \\users\username\AppData\Local\Temp\Low is automatically created for all other user accounts except the Built-in Administrator. Since the "Low" folder is not created in the code it failed to find the location for the Built-in Administrator.
The current workaround for Built-in administrator is to create the "Low" folder manually in \\users\username\AppData\Local\Temp. Then, run installer and it will work.
pierre_pierre
Re: Java and Win7
still cant make it work
matt_2k34
Re: Java and Win7
bad download?
id make sure theres no copies of java on the machine as OJ said...
then try and get the latest one..
also - if your on 64bit, install the 32bit version of java (as your browser, is 32 bit - unless you specifically state using 64, which i wouldnt recommend..)
pierre_pierre
Re: Java and Win7
Looking into the internet, it seems that you should disable and then enable Window:installer as that is the problem, but how the heck do you do it in Win 7 spent three days so far in the maze of control panel and cant find it.
And on the Java download page it doesnt ask you if you want 32 or 64 bit
And I have remove all traces of Java with REVO uninstaller
matt_2k34
Re: Java and Win7
Java download
top one - as stated in brackets is 32 bit
second - as stated in brackets is 64 bit
download to desktop, then run properly Smiley
pierre_pierre
Re: Java and Win7
can you explain what solaris is as there are no parenthesis on the Java downloads
pierre_pierre
Re: Java and Win7
and the Solaris download has a .sh extension not .exe
matt_2k34
Re: Java and Win7
your looking under solaris, not windows (which is above)
Solaris is another operating system, made by SUN Microsystems (people who make java) Smiley
pierre_pierre
Re: Java and Win7
look at my pic where does it say 32 or 64?
pierre_pierre
Re: Java and Win7
just been round a few more circles, latest 6-18, again windows:install failed to find file
matt_2k34
Re: Java and Win7
Right - your using Firefox (which you didnt say before  Roll eyes  -  Sun give different links dependant on browser Smiley )
if you click my link in IE, it specifies both.
in FF you can just go for the offline installer (the second link for windows, there both 32 bit unless you change it)
pierre_pierre
Re: Java and Win7
dont they make things award, and to prove it
Download  Speed
2923 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 2923 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
matt_2k34
Re: Java and Win7 - cured at last
Ahh glad you got it working Smiley
shame about the download speed you got Smiley heh
