Java Applets - how do you install them ?
- Re: Java Applets - how do you install them ?
08-03-2008 4:21 PM
You do not have Java applets
enabled in your web browser.
How do I install them so that I can run the BT Speed Tester?
08-03-2008 4:25 PM
Internet Explorer:
Go to Tools > Internet Options. In the Advanced tab, ensure "Use JRE xxx for <applet> (requires restart)" is checked. If this option doesn't exist, then you need to download the Java Runtime Environment, which can be obtained from Sun Microsystems
Mozilla Firefox:
Go to Tools > Options. Select content and ensure "Enable Java" is checked.
Hope this helps.
08-03-2008 4:32 PM
Thanks for the quick response.
That option is already checked in Internet Explorer - any other ideas?
08-03-2008 4:54 PM
08-03-2008 7:33 PM
I've tested with the following results:
1) Java Coffee Cup in system Tray
Version 1.6.0 (build 1.6.0_03-b05)
2)Java Console
1.6.0_03
Using JRE Version 1.6.0_03
3)Active X Control
(see attachment)
4) From Command Prompt
java Version "1.6.0_03"
Runtime Environment (build 1.6.0_03-b05)
08-03-2008 8:48 PM
Sorry about the late response - I fell asleep while watching TV.
If you could try this for me please, in Internet Explorer go to Tools > Internet Options. Under the Security Tab, press the Custom Level button. Once inside, scroll down to "Scripting of Java Applets" and make sure this is enabled, then restart Internet Explorer fully and try the speed tester again.
Let me know how you get on.
09-03-2008 7:29 PM
Hope you've recovered from your heavy sesh
The Scripting of Java applets is enabled?
What now ?
09-03-2008 7:41 PM
10-03-2008 11:23 AM
I have 3 PCs connected to my home network via a Netgear router. They are all physically connected with Cat5e cable.
Yes, I am having some problems with my W98 PC but this Java problem is new to my XP PC.
The script was already enabled and I have just tried once again to run the speed tester but it still returns an error.
10-03-2008 1:20 PM
You learn something new everyday.
Thanks for you help anyway !
