Itunes
Itunes
I am having a problem installing itunes on my windows xp pro computer. Each time I try to install it comes up with an error saying the path "program files" has an illegal  character  and then it aborts the installation.
This is driving me nuts!  I have just purchased an ipod shuffle and at the moment I am unable to use it.
Can any one help with this problem or give me a work around that will allow me to use my ipod shuffle?
Regards,
Jevo
2 REPLIES 2
Re: Itunes
Hi Jevo
Are you using the default path for installation? If not make sure you havn't included any of these "\\/:*?\"<>|"; As they are not allowed as part of the filename.
If this doesnt  help can you copy the exact installation path you are using and error message here?
Re: Itunes
Does iTunes show up under your programmes in add/remove programmes in control panels?  Also, is there a folder for it under C:\Program Files?
I'd try uninstalling the programme (if relevant) and deleting the folder (if relevant).
