Issue with latest CCleaner update
- Re: Issue with latest CCleaner update
21-03-2017 6:36 PM - edited 21-03-2017 6:37 PM
Is anyone else having trouble getting the latest update to start downloading using the link from this page?
Normally, once you get to the next page, after a short delay for the video to start the download link pops up but that is not happening. I have tried using latest versions of FF, Chrome and IE.
Forum Moderator and Customer
21-03-2017 6:43 PM
@Mav - I always get mine via Filehippo, never had a problem with thatt, and updated last week.
21-03-2017 6:49 PM
Had a couple of failed installs and ended up here http://www.piriform.com/ccleaner/download/standard.
21-03-2017 6:53 PM
Clicking the large green 'free' button takes you to the Filehippo page.
Odd that when I leave that page long enough JDownloader2 picked up the download but there was no pop-up.
Thanks for that link.
21-03-2017 6:55 PM
Yup, looks like Filehippos got it's knickers in a twist.
21-03-2017 6:57 PM
Glad it's not just me
22-03-2017 7:10 AM
i get mine from here http://www.filecroco.com/download-ccleaner
22-03-2017 11:00 AM
open ccleaner... click the "Check for updates" on the bottom right corner... takes you to this page..
http://www.piriform.com/ccleaner/update?v=5.28.6005&l=1033&o=6.1W6&au=1
Scroll down the list, and click "No Thanks" takes you to another page of lists of "goodies"
http://www.piriform.com/ccleaner/download?upgrade
again... scroll down the list of "FREE" column... and click "Download"
Takes you to another site... http://filehippo.com/download_ccleaner
click the green box on the right "Download latest version" .....
Takes you to yet another page ... http://filehippo.com/download_ccleaner/download/5a9c8633b09f7cc60f94e311abdc517c/
Where the pop out informing you of the download appears click "Save File"... and then execute it after it finishes.
WHY ? what a load of effort... surely they could just give us a "one click" link... to the last one.. I used to complain about the Flash updater... taking so much time and effort.
Ridiculous..
22-03-2017 11:03 AM
Why not bookmark the page?
22-03-2017 11:08 AM
Would that bring up the latest update in 6 months time, though? or would it point to the one I just downloaded,.... ( i.e. 6 months ago, in 6 months time ? ? ? ? ?)
22-03-2017 11:11 AM - edited 22-03-2017 11:15 AM
@shutter - thats why I use Filehippo - when it works as it usually does, you get straight to the last link in your post.
The direct to Filehippo link will take you to the latest version - don't know if bookmarking your link would that, but I have the FH homepage bookmarked anyway.
