Issue with latest CCleaner update
Mav
Fixes: 515
Is anyone else having trouble getting the latest update to start downloading using the link from this page?
Normally, once you get to the next page, after a short delay for the video to start the download link pops up but that is not happening. I have tried using latest versions of FF, Chrome and IE.
Forum Moderator and Customer
10 REPLIES 10
Legend
Fixes: 253
Re: Issue with latest CCleaner update
@Mav - I always get mine via Filehippo, never had a problem with thatt, and updated last week.
Strat
Fixes: 565
Had a couple of failed installs and ended up here http://www.piriform.com/ccleaner/download/standard.
Mav
Fixes: 515
@jab1
Clicking the large green 'free' button takes you to the Filehippo page.
Odd that when I leave that page long enough JDownloader2 picked up the download but there was no pop-up.
@Strat
Thanks for that link.
Legend
Fixes: 253
Yup, looks like Filehippos got it's knickers in a twist.Wink
Mav
Fixes: 515
Glad it's not just meThumbs_Up
rongtw
Fixes: 12
i get mine from here Thumbs_Up http://www.filecroco.com/download-ccleaner
shutter
Fixes: 65
open ccleaner... click the "Check for updates" on the bottom right corner... takes you to this page..
http://www.piriform.com/ccleaner/update?v=5.28.6005&l=1033&o=6.1W6&au=1
Scroll down the list, and click "No Thanks"   takes you to another page of lists of "goodies"
http://www.piriform.com/ccleaner/download?upgrade
again... scroll down the list of "FREE" column... and click "Download"
Takes you to another site...    http://filehippo.com/download_ccleaner
click the green box on the right "Download latest version" .....
Takes you to yet another page    ...   http://filehippo.com/download_ccleaner/download/5a9c8633b09f7cc60f94e311abdc517c/
Where the pop out informing you of the download appears     click "Save File"... and then execute it after it finishes.
WHY  ?  what a load of effort... surely they could just give us a "one click" link... to the last one..   I used to complain about the Flash updater... taking so much time and effort.
Ridiculous..
Mav
Fixes: 515
@shutter
Why not bookmark the page?
shutter
Fixes: 65
Would that bring up the latest update in 6 months time, though? or would it point to the one I just downloaded,.... ( i.e. 6 months ago, in 6 months time  ? ? ? ? ?)
Legend
Fixes: 253
@shutter - thats why I use Filehippo - when it works as it usually does, you get straight to the last link in your post.
The direct to Filehippo link will take you to the latest version - don't know if bookmarking your link would that, but I have the FH homepage bookmarked anyway.
