Is using Trusteer Rapport a good security addon
- Is using Trusteer Rapport a good security addon
- « Previous
- 1
- 2
- Next »
Re: Is using Trusteer Rapport a good security addon
16-05-2012 4:51 PM
16-05-2012 8:34 PM
I had it installed ever since Natwest offered it when I was using IE6.0. Since I moved over to FF, it had worked fine. Until, the last few updates of FF. The Rapport used to work in the background, but NOT showing its Icon on the Address Bar. So, I could never be sure which sites were protected and which were not.
On Every update of FF causing this issue, I had contacted Trusteer (via their Console) telling them of the issue and they have come back with the correct version of Trusteer Rapport. And each time it has worked.
As for how effective it is, on each protected site if I had entered an incorrect password, it does query it etc. So, I have found it quite helpful.
As for uninstalling, the Rapport, as said earlier use the safeunintall.exe which Trusteer have supplied to me.
So, I would say go for it Jim.
Regards,
Chandu.
09-03-2013 8:56 PM
13-03-2013 11:28 PM
14-03-2013 8:40 AM
I had it in mind to see if things have improved by checking the latest version with my AV, but not got round to it yet.
07-05-2013 6:44 AM
07-05-2013 12:32 PM
11-05-2013 10:20 AM
11-05-2013 1:09 PM
14-05-2013 2:57 PM
- « Previous
- 1
- 2
- Next »
