Is this Possible ??
Fixes: 9
Is this Possible ??
An Elderly relative has recently purchased a new camera which includes a CD. This contains the instruction Manual but the problem is he does not own or want to own a computer.
He has asked me is there any way I can transfer the manual on to a dvd so he can play it on his dvd player ? I suspect the answer is no or if it can be done then it would be way beyond my skills.
The easiest option would be for me to print the manual out providing it's not too long or copy & paste relevant extracts from the manual but just out of interest is it possible to do what he was asking ?Huh
Fixes: 62
Re: Is this Possible ??
If his DVD player will play jpg files you can convert each page to an image and put them on a CD
http://www.infopackets.com/news/hardware/2005/20050216_view_digital_photos_in_home_dvd_player.htm
Fixes: 9
Thanks for that link.
I Have an old copy of proshow gold so if I convert the images to jpegs I could just drag & drop them into proshow and burn that using the same program.
Thanks again for the link.
