Is the Epson XP-212 WiFi AIO Printer worth investing in ??
TORPC
It will be replacing an Epson stylus SX115
Mainly for the WiFi capability & to print from Phablet & Tablets alike, since the SX115 does not have WiFi capability
Asda are slightly cheaper that Argos
http://direct.asda.com/Epson-Expression-Home-XP-212---multifunction-printer-%28-colour-%29/000514789...
http://www.argos.co.uk/static/Product/partNumber/1872794.htm
Data Sheet .PDF
Product description / spec
Printer:
Compatible with PC and Mac.
A4 print speed - black text: 6.2ppm (pages per minute).
A4 print speed - colour text: 3.1ppm (pages per minute).
Up to 5760 x 1440dpi print resolution.
50 sheet paper capacity.
Uses 4 ink cartridges.
Scanner and copier:
1200 x 2400dpi optical resolution.
Card slots.
USB port.
Connectivity:
USB .
Wireless/WiFi enabled.
Mobile print enables printing direct from your smartphone or tablet through brand specific apps.
General information:
Photo editing software included.
Weight 3.9kg.
Ink cartridge included.
Size H145, W390, D300cm.
EAN: 8715946527390.
Nice little tip
5 / 5
Excellent quality prints from a compact device
15 February 2014
MrBee
Gender:Male
The printer worked perfectly out of the box with a USB cable but initially it would not connect to the Wi-Fi until it did an automatic firmware update.
I also found that when I pressed the Info button on the front panel it printed out the WPS-PIN code in order for me to be able connect it to my router. (Strangely, I couldn't see this tip anywhere in the set-up instructions).
Very pleased.
10 REPLIES 10
shutter
Fixes: 64
Re: Is the Epson XP-212 WiFi AIO Printer worth investing in ??
With respect, to the original post title question....
Only if it is kept in the box, un-used, and in pristine condition, with the original purchase receipt...... for 100 years... it will then be classed as and antique, and "probably" worth quite a bit, being the only example of primitive 21st century printing equipment.
Oh, and remember to keep the box in good condition too, as collectors do like them to be unmarked....
TORPC
Perhaps I should of known better to have worded the title Wink
All giraffes aside
I meant as in a working unit unboxed Roll_eyes
shutter
Fixes: 64
Hmm.... Collectors do like to have the original box, in good condition, if possible.... without the box, it loses some value, for some reason... Cry
I am not an expert in this, but have watched quite a lot of Antique programs lately...  Wink
w23
Fixes: 4
The reviews shown on your first link suggest that it might not be the best choice (though not that many reviews and some people will post a bad review for the strangest of reasons).
I used to really like Epson printers but I've been rather disappointed in the (lack of) reliability of my last two, now using HP which (so far) are proving very acceptable.
Call me 'w23'
TORPC
I used to be a HPaholic
Until I was given a now old defunct Epson printer, which I found much cheaper on inks
The SX115 does not miss a beat & the quality is on par with HP, however as need to future proof with the increasing use of tablets  phablets etc it is felt necessary to upgrade to the flavour of WiFi printing & this looks to suit our needs.
Was hoping for some members to be using it, so i could get an impartial review
Referring to reviews
You are right as more negative reviews get posted rather than positive reviews
Some bad reviews could be a result of a conflict software / virus or other anomaly that some can not get it working / drivers installed from disc etc
w23
Fixes: 4
Do you have spare inks for your existing printer?
If so, is it possible to find one that suits your needs that uses the same inks?
Call me 'w23'
pwatson
Quote from: TORPC
Then you misunderstand the purpose of wifi in printers...
TORPC
Quote from: 77
No that is why we are keeping our options open
@pwatson
Can you please elaborate
As using an app from tablet / phablet to the printer via WiFi will activate printer on command (will it not), thus no need for the USB cable in such cases
Mav
Fixes: 510
Quote from: 77
+1
Forum Moderator and Customer
TORPC
Thanks for all your input everyone
Much appreciated Smiley
