Is my desktop ready for the scrap heap?
- Re: Is my desktop ready for the scrap heap?
02-11-2010 7:53 PM
Quote from: A If you have a spare couple of weeks, you could erase and install Windows and all its miscellaneous drivers etc.
Then reload service packs and hundreds of security patches.
Then you could re-install all the separate applications.
It will then run almost as fast as new.
While you've not directly said anything bad about Windows the underlying tone makes it more than clear that you are bashing it.
We've already had the linux debate here and now its been silent for a while you're back trying to put off the op from using Windows.
02-11-2010 8:57 PM
Quote from: A I haven't any experience at reconstructing the XP version (yet) - but I've had problems with Win98, NT and 3.1 series..........
Jeremy, what you are saying is you have no actual experience re-installing any version of Windows since those of the 1990s. That's a long time ago now!!! You say you are not here to bash Windows but in that case what are you actually contributing to this thread?
02-11-2010 9:25 PM
I have recently rebuilt a mates laptop, a very old tosh satellite 1130. Downloaded the drivers from Toshs website easily, and the whole thing, including installing office, acrobat and all updates took about 3-31/2 hrs. ( I must admit i was using one of my custom XP disks, with SP3, IE8, WMP11 and Ryans Update pack from around 6months ago )
Laptop ran much faster and smoother after this.
02-11-2010 9:39 PM
Quote from: ReedRichards
Well said.
@penfold: I've also reached the conclusion that XP is very easy of all the Windows systems I've used. Never had a problem with drivers, it recognises most devices easily and the networking support is also very good.
Not to mention that every organisation I've worked for recently has also used XP... and nothing newer I might add.
02-11-2010 10:20 PM
I cannot understand why the mere suggestion of carrying out a re-install should cause such widespread accusations of Windows bashing.
I could have said much worse things - but that would have been off-topic - so I didn't.
02-11-2010 10:34 PM
Quote from: A mere suggestion
You know, and we all know, it was much much more than that.
Time to withdraw with dignity methinks.....
02-11-2010 10:45 PM
02-11-2010 10:51 PM
that is the issue.
02-11-2010 11:06 PM
You can add Office, non-essential drivers, updates to Windows in an incremental way.
etc.
I was talking about total elapsed time BTW - tea breaks are allowed.
03-11-2010 12:36 AM
Fox, face it, you've been had. Everyone here can see what you were getting at, you just can't admit you were wrong.
I'd suggest no more replying here foxy as you're digging yourself a deeper hole with each reply.
19-02-2011 11:03 PM
20-02-2011 12:12 AM
Quote from: A
Sorry - where did I bash this thread?
If you look at the timeline of this thread, I'll admit I was badly wrong in saying a couple of weeks elapsed time...
Several months would appear to be a better estimate...
20-02-2011 9:26 AM
20-02-2011 1:45 PM
Nice to hear you at least you tried Linux, though.
I'm in the process of reinstalling Ubuntu on a 600MHz, 384MB PC which has BIOS that claims it is "Y2K" compliant.
27-07-2011 11:52 AM
It now makes a clicking noise whenever it gets to the Starting Windows part of booting up, I've tried booting on the old XP system, with the new XP disc installed, with the disc on 'Repair' facility, in various Safe Modes, but the clicking continues and nothing happens.
I've switched on with the cabinet side removed and the fans whir away happily.
I think the hard drive has had it, but there is one file I would like to gain access to if I can. Is there any way of doing it? I don't have another spare desktop.
