Is it possible to link 2 computers
diabeg
hello
I am new to this forum and this may be a daft question
I have a desk top and a laptop (using wireless)
is it possible to access the one computer with the other via the router
Thank you
diabeg
8 REPLIES 8
HPsauce
Re: Is it possible to link 2 computers
Yes, and it's commonplace.
What operating systems (and versions/editions) are they running?
Note that some routers can be configured to prevent this, but normally (by default) it's not blocked.
jelv
Fixes: 10
When you say access do you mean access files and printers on the other machine or bring up the desktop of the other machine and use it as if you were sat at it (both are possible).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
diabeg
Quote from: HPsauce
My Desk top runs windows 7 and my lap top runs windowsxp
diabeg
Quote from: jelv
I would like to do both if possible But does that mean that both would have to be running at the same time.
At present I use an USB stick with all my documents on and then insert it it in either the desk top  or the lap top and just maybe this is my best option
Anotherone
Champion
Fixes: 21
I would say using a USB stick was a good option for documents that contain any personal data, any form of bank or utility account information etc. etc. and on either machine they should be restricted to the My Documents folder or similar - those folders that can only be accessed by the individual user or admin (although if you really get down into the nitty gritty of security you can restrict things even more).
You can use the Shared Documents folder for any that you are happy to share more or less with anyone.
diabeg
Thank you very much for your interest in my query and for your very helpful reply.
I will do as you suggest and stay with my trusted usb,s
Best wishes
diabeg (which is a beautiful place in Scotland)
jim:quote
HPsauce
I know Lower Diabaig........
HPsauce
Quote from: diabeg
If they work for you and you don't need frequent access that's probably the best solution.  Cool
Network access between XP and W7 can be a little problematic at times
(I'm a supposed IT expert and do it regularly but I still encounter unexpected problems  Lips_are_sealed )
