Is it possible to get remote access to Plusnet Sagemcom 2704N router?
- Is it possible to get remote access to Plusnet Sag...
23-04-2015 7:50 AM
As the title
Possible?
Possible?
5 REPLIES 5
Re: Is it possible to get remote access to Plusnet Sagemcom 2704N router?
23-04-2015 9:53 AM
I don't believe so, no.
23-04-2015 9:58 AM
Ok thanks for the reply.
23-04-2015 10:44 AM
What are you wanting to achieve exactly?
23-04-2015 11:13 AM
Wanted to reboot my router.
23-04-2015 11:29 AM
If you have some technical knowledge there may be some threads about the 2704n on the Hardware Board that might point you to a method of doing this. But I've also a feeling that this may be achievable with some software packages used for handling of a remote setup. There's also a thread on a related issue on the ADSL board.
Your thread would be better on the Hardware board anyway IMHO, but whether the mods will move it?
