Is Plusnet causing this problem?
- Is Plusnet causing this problem?
Re: Is Plusnet causing this problem?
02-01-2011 5:32 PM
02-01-2011 5:54 PM
You are currently connected to the gateway known as ptn-ag04.
This is located in Telehouse North.
02-01-2011 6:43 PM
Quote from: pierre_pierre You are currently connected to the gateway known as ptn-ag04.
You may be on to something there, as I'm also connected to ptn-ag04 and haven't had the problem.
A traceroute would also show which gateway the OP is using.
Jonny.
02-01-2011 7:03 PM
jason@Lucy:~$ traceroute www.rcgroups.com
traceroute to www.rcgroups.com (66.228.117.24), 30 hops max, 60 byte packets
1 h254.home.com (192.168.255.254) 1.271 ms 1.795 ms 2.302 ms
2 lo0-central2.pcl-ag04.plus.net (195.166.128.242) 26.480 ms 27.019 ms 27.795 ms
3 gi1-12-421.pcl-gw01.plus.net (84.92.6.232) 19.999 ms 21.534 ms 22.944 ms
4 * * po4.pcl-gw02.plus.net (212.159.1.129) 30.374 ms
5 * * *
6 * * *
7 * * *
8 * * *
9 * * po4.pcl-gw02.plus.net (212.159.1.129) 12.554 ms !H
It is now looking like a Plusnet problem I think.
02-01-2011 7:05 PM
Tracing route to rcgroups.com [66.228.117.24]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 33 ms 33 ms 35 ms lo0-central1.pcl-ag02.plus.net [195.166.128.235]
3 184 ms 73 ms 31 ms gi1-13-211.pcl-gw01.plus.net [84.92.6.32]
4 32 ms * * po4.pcl-gw02.plus.net [212.159.1.129]
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10
02-01-2011 7:15 PM
02-01-2011 7:22 PM
Quote You are currently connected to the gateway known as pcl-ag02.
This is located in City Lifeline House.
Could be a problem with that gateway then?
02-01-2011 7:26 PM
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\MEDION>tracert www.rcgroups.com
1 60 ms 98 ms 99 ms dsldevice.lan [192.168.1.254]
2 23 ms 22 ms 23 ms lo0-central3.ptn-ag04.plus.net [195.166.130.24]
3 230 ms 153 ms 173 ms gi2-22-431.ptn-gw01.plus.net [84.92.2.145]
4 21 ms 22 ms 24 ms t2a1-ge2-0-0.uk-lon1.eu.bt.net [166.49.211.45]
5 22 ms 22 ms 22 ms t2c2-ge2-0-0.uk-lon1.eu.bt.net [166.49.135.109]
6 22 ms 22 ms 23 ms t2c1-p4-0.uk-eal.eu.bt.net [166.49.208.109]
7 105 ms 106 ms 104 ms t2c1-p4-0-0.us-ash.eu.bt.net [166.49.164.225]
9 108 ms 109 ms 109 ms po3.bbr02.tl01.atl01.networklayer.com [173.192.1
8.153]
10 131 ms 130 ms 131 ms po7.bbr02.eq01.dal01.networklayer.com [173.192.1
8.134]
11 144 ms 152 ms 159 ms po5.dar02.sr01.dal01.networklayer.com [173.192.1
8.203]
12 328 ms 235 ms 228 ms po2.fcr01.sr01.dal01.networklayer.com [66.228.11
8.158]
13 131 ms 130 ms 129 ms www.rcgroups.com [66.228.117.24]
Trace complete.
C:\Users\MEDION>
02-01-2011 9:12 PM
Quote from: jelv Between attempts that succeed and fail will you have reconnected the router?
The reply was
Quote from: Flypopa The router has not been touched,
03-01-2011 3:19 AM
I have just replied to your ticket and passed this matter through to our networks team as I am unable to access the site also from our offices. I have noticed however that when i use a online proxy such as http://www.anony-surf.com/ I am able to get to the website with no issues, so it could be an issue with ourselves but we will have to wait and see what networks find out.
Chris Dawson
03-01-2011 10:01 AM
to acess the site.
It is being looked into.
Thanks folks for your help on this.
03-01-2011 1:01 PM
You got me going earlier, as you didnt have your PN parts, thought it was an outsider with a queer post. now it makes sense
03-01-2011 5:01 PM
You live and learn!
04-01-2011 3:58 PM
Have 'Plusnet' fixed something?
05-01-2011 8:49 AM
I've replied to your ticket, I'd just noticed it was back up and running, as far as I can see nothing was actioned this side, Dean in Tech told us you were having issues as he saw your post.
If it does go down again let us know asap and we can find out what's going on for you! Though I'm glad it's working now
