Is 500W enough?
- Is 500W enough?
- « Previous
- 1
- 2
- Next »
Re: Is 500W enough?
31-01-2009 11:41 AM
Quote from: jmart That was a total bust!
Same problem with both PSUs. Reckon it's RMA time.
What was the spec of the second PSU?
Let us know how the RMA goes.
Re: Is 500W enough?
31-01-2009 7:51 PM
I'll keep you up to date, hopefully be good news from here on in.
Re: Is 500W enough?
01-02-2009 9:25 AM
Have a glimp at this guys article, and pay particular attention to what he says about +12v rails: http://compreviews.about.com/od/cases/a/PSUWattage.htm.
Re: Is 500W enough?
09-02-2009 7:26 PM
Guess it's faulty PSUs at my end.
Re: Is 500W enough?
10-02-2009 12:38 PM
I'm going for the best that I can afford that's got at least 30A on that 12v rail and 6 molex power connectors, so I've got a dedicated supply solely for my video card.
You can't get a too powerful PSU because the system will only use as much as it needs.
Re: Is 500W enough?
10-02-2009 4:10 PM
I got my local friendly dealer to check things out for me and it appeared that the PSU had several problems;
Mainly, the power output was nowhere near the rated output and there was a loose (burnt) connection which could have been the cause of the hard drive failures.
I have now got an expensive 700W PSU and haven't looked back since.
Forum Moderator and Customer
Re: Is 500W enough?
10-02-2009 4:54 PM
Quote from: okrzynska Camera flash circuits... now they're fun if you want to learn to fly Last time I hit one of those I tele ported 2 feet backwards and landed in the wall
Yep, a friend of mine realised that taking one of those disposable cameras apart was not a good idea
Re: Is 500W enough?
10-02-2009 6:41 PM
- « Previous
- 1
- 2
- Next »
