Ipod sync problem
tonka
Ipod sync problem
Hi,i have had to get a new tower due to my old one failing big time and when i try to sync my ipod to it its telling me it cant because its already been sync to my old tower and if i wanted to carry on my music would be wiped from my ipod,now this is problem as my new tower hasnt any music on it and the music i really want is on the ipod so wondered if it was possible to get the music off my ipod to transfer to my new tower.
Fixes: 246
Re: Ipod sync problem
Yamipod should be able to help you http://www.yamipod.com/main/modules/home/
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
tonka
Cheers will try but noticed it might not support ipod touch.
Fixes: 246
you didn't say which ipod you had Smiley
tonka
Sorry its a ipod touch lol.
Fixes: 62
