Iphone wifi my Thomson Plusnet wireless broadband
onelegmummy
I am really sorry  I am probably being really thick.
How do I get my iphone to use my wireless connection at home?
Ihave a Thomson wireless router.  I know the password.
I have wifi turned on my iphone when I put the password in (when prompted) it does not make the join button illuminate until I press space bar then it says unable to connect.
What am I doing wrong?
Cheesy
1 REPLY
matt_2k34
Re: Iphone wifi my Thomson Plusnet wireless broadband
Only just looked at mine so could be a complete guess ! Smiley (and i dont use mine for wifi heh)
But the front theres a "button" with a wifi signal on... i know from previous experience that sometimes you have to push that button, when you first set up the pairing (like pairing a bluetooth device)
Try that, if not im not sure tbh Smiley
