Iphone and DG834GT
- Re: Iphone and DG834GT
Iphone and DG834GT
07-02-2012 11:52 AM
I've changed my router from the standard PN Thompson to my old netgear DG384GT as it gives out a better wireless signal.. I'm havig a few problems connecting my wifes iphone. I can get it to connect if i reboot the router but once she leaves the house and comes back it wont connect until the router is switched off and on again.. any ideas on the fix?
11-02-2012 12:10 AM
Do other devices, such as a laptop or PC have the same issues at all? Or is it just with the iPhone?
11-02-2012 9:38 PM
I dont want to keep switching my router on and off as my sync speed has dropped by 1mb while ive been messing about trying to get it to work so for the time being ive switched back to the thompson router while i find a fix.
11-02-2012 10:22 PM
Login to the DG384GT web interface, then navigate to the "Advanced" -> "LAN IP Setup" screen.
In the section called "Address Reservation" hit the "Add" button (and wait a few seconds).
You should now see the "Address Reservation Table", and one of those entries will be your iPhone.
In the left hand column, select the line that corresponds to your iPhone, and the details will be copied to the section below the table.
If the "Device Name:" is showing "UNKNOWN" then edit it to something like "Wifes iPhone"
Hit the "Add" button.
Check the correct details are now displayed in the "Address Reservation" table.
Job done
11-02-2012 10:37 PM
11-02-2012 10:44 PM
11-02-2012 10:56 PM
13-02-2012 10:51 AM
Hope it worked for you, please let us know how it goes/went
14-02-2012 9:20 AM
im going to try this around lunch time today as i belive thats the best time of day to reboot and sync the router as the snr is at it its highest so ill get the best possible sync speed? Or have i got this wtong and i should reboot when the snr is at its lowest?
14-02-2012 10:02 AM
14-02-2012 10:08 AM
14-02-2012 10:27 AM
14-02-2012 5:33 PM
