Interrupting shutdown updates
- Re: Interrupting shutdown updates
11-02-2016 8:02 AM
Any suggestions please, before I hard power down?
11-02-2016 1:31 PM
If it's still responsive, take a backup of the vital stuff before you do a hard power down.
11-02-2016 1:41 PM
11-02-2016 7:37 PM
11-02-2016 11:00 PM
12-02-2016 10:24 PM
12-02-2016 11:31 PM
at east that's how I get round the wifi cutting out issue on shutdown /download
13-02-2016 12:07 AM
Updates are never forced on you though.
13-02-2016 12:16 AM
Quote from: vilefox Updates are never forced on you though.
which potentially compromise security, there's pro's and con's for both methods but decades of research has clearly proven the windows 10 method to be better than prior iterations with so many people claiming their system was corrupted by M$ in the past because they failed to do an update and got compromised and a follow-up update borked the system .... to be honest I don't understand why they didn't just have it instantly download the updates the second they became available and installed at next shutdown /restart, it would do them in a more timely manner
either way I'm one of those that has always done the updates the day they became available and now I don't have to go round the house making sure each of the kids does them on time either since the pc automatically does them for them
13-02-2016 7:09 AM
13-02-2016 9:23 PM
Thanks to all for your help
15-02-2016 8:48 AM
Have not tried switching back to manual after the latest batch of updates to see whether the problem persists...
15-02-2016 3:10 PM
18-02-2016 1:45 PM
The update has worked okay, but now I need to warn my wife about this little trick of MS
Cheers
19-02-2016 3:05 PM
Have to say, I upgraded my own laptop (Windows 7) and my work laptop (Windows 8.1) to Windows 10 within a week or two of it's release and I've been very happy with it on both machines - having to work on Windows 7 at client sites now feels like going back to the dark ages
I did have two issues, though. The first was with some VM software (VMWare?) when I initially upgraded the work laptop. I simply rolled back to Windows 8.1, got the VM software working, then did the Windows 10 install again and everything worked fine.
The second issue was with drivers for my 3 (?) year old HP printer/scanner/etc. Once HP got around to releasing drivers for Windows 10, everything worked fine.
Some of my colleagues had issues with Dell laptops that came with SSD drives as Dell took their time releasing the appropriate drivers. Both my laptops are Dells and both have after market SSDs: I haven't had issues with either.
Basically, unless you're concerned with the amount of data about you that MS are gathering via Windows 10 (if you are, then you'd probably best go Linux), I wouldn't wait to upgrade. You have a month or so to change your mind anyway - as mentioned above, I've used the rollback to the previous version and it works.
