Internet crashes
- Internet crashes
Internet crashes
31-03-2010 4:12 PM
For some years my network at home has worked fine. It consists of a BT Voyager 205 ADSL router and a net gear switch connected to which are 2 PCs which are networked together to allow file sharing, and a laptop all of which are running windows XP professional. All of these are plugged into the router or switch.
I recently got my son a laptop (Windows 7 professional), but when that is connected to the Net Gear switch it causes the Internet connection to fail. Not as soon as it is connected, it will usually work okay for a time but then the Internet connection fails, to all of the computers which are working at that time. When it fails I have found that to get back onto the Internet I have to turn the BT router off and then on again after a short while.
I only have this problem when the Windows 7 laptop is connected It does it when only the Windows 7 laptop is on, as well as when the Windows 7 laptop is on with my other computers. But when the Windows 7 laptop is off everything worked fine.
Any ideas?
Any ideas?
1 REPLY 1
Re: Internet crashes
03-04-2010 9:13 AM
Coincidence! Those BT Voyager routers don't last forever and yours is probably coming to the end of its life.
