Internet connection indication ikon
- Internet connection indication ikon
06-07-2011 12:57 PM
Re: Internet connection indication ikon
06-07-2011 10:02 PM
I'd check to see if the nm-applet (I think that's what it's called) is running.
I don't have access to anything using NetworkManager right now, aptosid/KDE gives me three different icons for 3G, Ethernet, & Wireless networking.
07-07-2011 9:08 AM
The icon will change dependant on connected/not connected.
07-07-2011 11:43 AM
Looked at listed optional icons but Network manager does not appear on it. The search continues! But thanks anyway.
C.
07-07-2011 3:05 PM
07-07-2011 5:34 PM
C.
07-07-2011 6:08 PM
08-07-2011 1:24 AM
If your web browser stops working, you could ping a couple of well known sites...
08-07-2011 7:44 AM
08-07-2011 3:04 PM
C.
08-07-2011 6:14 PM
24-07-2011 6:09 PM
Mark
25-07-2011 2:55 PM
If you look earlier in the thread you will see that the Notification Area is present in my set-up but the connection indicator just does not seem to be an option any more. I note that you say that you lost it and got it back but what version of Ubuntu are you using? I have not found much more about this problem despite the valuable advice above, just a bit busy to spend time on it right now.
Thanks for your interest.
26-07-2011 9:29 AM
I suspected I hadn't grasped the problem exactly, but thought 'who knows?'. I was using 10.04 until very recently, and fixed the problem there. In the past few days, frustrated by address book sync problems (and long term Ubuntu One inactivity), I upgraded to 10.10, where I removed and re-installed the said indicator. I'll update my profile with relevant os details. Mark
