Internet auto log in, on boot up of windows xp on dell latitude D530
- Internet auto log in, on boot up of windows xp on ...
12-09-2015 1:38 PM
My P.C. will not log on to the internet (plusnet Wi-Fi Network) automatically on start up.
I have to go into Network connections and choose plusnet,then choose, change settings for this connection.
and click the Use windows to configure my network connection,every time I Start up or go in to stand by,
Please HELP.
Please HELP.
3 REPLIES 3
Re: Internet auto log in, on boot up of windows xp on dell latitude D530
12-09-2015 2:20 PM
Welcome to the forum...
click on the WIFI icon , bottom right corner ....Right click on your connection ( assume it is now connected)... then click on "Properties".... then click on the "connection" tab.... then make sure you have a tick in the box next to " connect automatically when this is in range".....
should connect automatically on next boot up....
14-09-2015 7:32 PM
:'(Unfortunately I have gone through all the suggested requirements and it still will not work.
coke.
coke.
14-09-2015 9:16 PM
Hi
It sounds like you have a conflict between the Dell wireless utility and Windows.
This may be useful is disabling the Dell version
http://kb.netgear.com/app/answers/detail/a_id/20701/~/disabling-various-third-party-wireless-card-ut...
Let us know how you get on.
