Internet Explorer
- Internet Explorer
Internet Explorer
13-11-2007 10:48 PM
Having new problem with IE 7. If i am on my home page, the writing on the main part is small. However when i move upwards,
ie @ the favourite symbol, then up to tools then file, edit, etc and everything else is quite large.
Can anyone help me?
Can anyone help me?
4 REPLIES 4
Re: Internet Explorer
14-11-2007 12:01 AM
on the right hand side is an icon that says page. Hit that and you get a drop down box You can then Zoom or change the font size which ever you want
14-11-2007 1:39 AM
The following is a bit of a heavy handed solution, but I like to do it now and again:
Tools\Internet Options\Reset... This will put IE7 back to its original state, including dumping Toolbars, add ons etc.
Used by some as a last resort and by others as a spring cleaning exercise!
19-11-2007 9:58 PM
Thanks very much, problem sorted out.
19-11-2007 10:47 PM
What did it turn out to be and what was your solution?
