Internet Explorer wil not connect.
paulo
My PC has suddenly decided not to connect to the net!!  On looking into this problem I get  'error 12029 Connection to server could not be established'.  I can still use Outlook Express to send emails OK so that seems to show my connection to router is working and my Plusnet account is valid etc.
My laptop still connects normally via the same router.
Any help or advice would be much apprciated.
OS is XP Pro.
I can resist everything except temptation.
25 REPLIES 25
Midnight_Caller
Re: Internet Explorer wil not connect.
Try clicking on your "C" Drive with the right mouse button and select disk scan, then do a full disk defragg.
Oldjim
Resting Legend
Fixes: 63
go into
Tools
Internet Options
Connections and LAN settings
Does it look like this
HPsauce
Seconded Oldjim.  Wink
I've seen quite a few systems lately where somehow proxy servers had been set, messing up IE connections.
paulo
Thanks Oldjim have done that and all is exactly as your pic.
Also done full defrag as suggested, no change in access.
Oldjim
Resting Legend
Fixes: 63
can you see the router from IE8 - put in the address of the router http://192.168.1.254 or http://192.168.0.1/ are the usual ones
paulo
Not able to connect to router via IE but I run a program called RouterStats-Lite that monitors my speed and noise ratio continuously and that is reporting as normal.
My radio link to router shows packets both ways.
Aubs
Have you tried another browser from the same 'offending' computer?
paulo
Not tried another 'browser'.  Not sure how I'm going to do that as I think there is only IE loaded.
Oldjim
Resting Legend
Fixes: 63
Download and install Firefox from http://www.mozilla-europe.org/en/firefox/
Aubs
You can download it like Oldjim said on the other computer that does work.
Alternatively, open Calculator Start --> Run and type in calc, then click OK, then click on Help --> Help Topics.
Top left corner, click on the 'piece of paper with a question mark' icon (in line with the close X) and select jump to url, then in the box that pops up, type in http://getfirefox.com
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: HPsauce
Somehow???  It's a computer virus (or "malware').  Even if your security software removes the virus, the proxy settings remain.  The point of the proxy is to control and monitor your internet connection.  But when the proxy server gets taken down by the authorities you lose your internet connection if the virus is not still active or smart enough to change to a new proxy server.
However that doesn't seem to be the problem here.  I would try Internet Explorer (No add-ons), to be found under Programs - Accessories - System Tools.  After it opens, try going to your home page.  If it loads now then an add-on is blocking your connection.
paulo
Have now tried IE without add-ons and can still not connect!!!
HPsauce
Quote from: ReedRichards
Often true, but can equally result from correct use on a corporate network or VPN.
Strat
Fixes: 565
Have you tried shutting everything down, PC and router for 15 minutes then restarting the router and then the PC when the router is fully up and connected.
There is also a Reset in IE...Tools...Internet Options...Advanced (but note the advisory).
