Internet Explorer wil not connect.
- Re: Internet Explorer wil not connect.
28-11-2010 10:38 PM
My laptop still connects normally via the same router.
Any help or advice would be much apprciated.
OS is XP Pro.
28-11-2010 11:49 PM
29-11-2010 9:17 AM
Tools
Internet Options
Connections and LAN settings
Does it look like this
29-11-2010 10:00 AM
I've seen quite a few systems lately where somehow proxy servers had been set, messing up IE connections.
29-11-2010 5:15 PM
Also done full defrag as suggested, no change in access.
29-11-2010 5:19 PM
29-11-2010 8:29 PM
My radio link to router shows packets both ways.
30-11-2010 1:04 PM
30-11-2010 8:37 PM
30-11-2010 8:48 PM
30-11-2010 9:26 PM
Alternatively, open Calculator Start --> Run and type in calc, then click OK, then click on Help --> Help Topics.
Top left corner, click on the 'piece of paper with a question mark' icon (in line with the close X) and select jump to url, then in the box that pops up, type in http://getfirefox.com
01-12-2010 11:12 PM
Quote from: HPsauce I've seen quite a few systems lately where somehow proxy servers had been set, messing up IE connections.
Somehow??? It's a computer virus (or "malware'). Even if your security software removes the virus, the proxy settings remain. The point of the proxy is to control and monitor your internet connection. But when the proxy server gets taken down by the authorities you lose your internet connection if the virus is not still active or smart enough to change to a new proxy server.
However that doesn't seem to be the problem here. I would try Internet Explorer (No add-ons), to be found under Programs - Accessories - System Tools. After it opens, try going to your home page. If it loads now then an add-on is blocking your connection.
03-12-2010 12:42 PM
03-12-2010 1:57 PM
Quote from: ReedRichards Somehow??? It's a computer virus (or "malware').
Often true, but can equally result from correct use on a corporate network or VPN.
03-12-2010 2:29 PM
There is also a Reset in IE...Tools...Internet Options...Advanced (but note the advisory).
