Internet Explorer - web addresses history
penneck
In this, the latest of several problems I have asked for help with, I am having problems with Internet Explorer.
On the Internet Explorer page, at the top where the web address is typed, there is (or used to be) a dropdown list of the web addresses I have accessed recently. For some unknown reason, it has been cleared of these addresses, and doesn't seem to want to remember anything before today.
Could I have wiped this memory accidently, such as using delete commands on the wrong directories/files? Is there some setup that affects whether previous addresses are remembered or not?
In Control Panel, there is under Internet Options, a thing about how long the history of your web usage is remembered. I have got that set to 20 days.
Thanks for any help offered.
4 REPLIES 4
Oldjim
Resting Legend
Fixes: 63
Re: Internet Explorer - web addresses history
Use Firefox  Grin
However using IE7 this is how to check your settings
penneck
Thankyou, OldJim
samuria
Spybot and some adaware type prog delete the history as it could be a security risk(very small but you dont want the wife knowing what you have been looking at). If you have used one of these it may have cleared it
penneck
Thanks OldJim and Samuria
